Spiderer Posted 16 minutes ago Share Posted 16 minutes ago Greetings to all, I possess a Mercedes C180K that displays the fault code P0100 – Malfunction in the Mass or Volume Air Flow Sensor Circuit. At reduced velocities, the engine's revolutions vary marginally, and the vehicle appears to be experiencing surges. I intend to either clean or substitute the MAF sensor and examine the breather hoses concurrently, yet I am encountering difficulties in detaching the air box. I have adhered to the procedures demonstrated in various online tutorials: - Detached the air intake duct. - Detached all connectors, encompassing the ECU connector. - Removed the two E-Torx fasteners securing the air box. I comprehend that these are captive bolts and must be elevated out of the path. - Employed extended hose-clamp pliers to disengage the clamp on the air-box hose. It is my comprehension that the air box ought to be retracted and elevated. Nevertheless, regardless of my efforts, I am unable to detach the hose from the air box, even after loosening the clamp. I prefer not to exert excessive force and potentially damage the plastic. To my knowledge, the air box has remained intact, leading me to question if the hose has become adhered over time. Am I overlooking a procedure, or is there a secure method to liberate it? Any guidance would be valued. Link to comment Share on other sites More sharing options...
Spiderer Posted 16 minutes ago Author Share Posted 16 minutes ago http://shop.ebay.co.uk/?_nkw=air+intake+hose&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338181132&toolid=10001&customid=2518X1570512X5d360692026ac9d44d2d4803b5458677&subId2=15 Link to comment Share on other sites More sharing options...
rauman Posted 15 minutes ago Share Posted 15 minutes ago This video effectively demonstrates the necessary steps to follow. Link to comment Share on other sites More sharing options...
rauman Posted 14 minutes ago Share Posted 14 minutes ago Link to comment Share on other sites More sharing options...
Spiderer Posted 14 minutes ago Author Share Posted 14 minutes ago I am encountering some challenges with this segment of the procedure, so I hope you can elucidate something for me. At 2:17 in the video, the clamp is released, a task I have also accomplished with the same instrument. My enquiries are: Should the clamp be elevated after being released, or is it acceptable to leave it in place? The device seems to exert force while maintaining the clamp's position. At 2:31, I am unable to detach the airbox from the pipe at the clamp, regardless of my efforts. This prompts me to question if the clamp must be elevated or displaced prior to the removal of the airbox. I would be grateful for some elucidation on this matter, as I am having difficulty detaching the airbox from the pipe. Link to comment Share on other sites More sharing options...
BrambleBurt Posted 14 minutes ago Share Posted 14 minutes ago If my recollection serves me correctly, the clamp is released yet remains in its position. The age of the materials may have caused the rubber and plastic components to adhere; apply some WD40 or a similar lubricant at the junction of the two parts near the clamp. I believe you will subsequently execute a strong push backward to initiate movement, as demonstrated in the video. I recall it being cumbersome. I composed a brief summary at the time of completion. Link to comment Share on other sites More sharing options...
Spiderer Posted 13 minutes ago Author Share Posted 13 minutes ago I appreciate it; I also surmise that the plastic hose is stuck due to the vehicle's age (2008). I considered applying WD-40, but I did not contemplate it extensively, to be frank. I appreciate the link; I will attempt it again and assess my progress. If everything else fails, a visit to the garage is necessary. Link to comment Share on other sites More sharing options...
