Mobile Charging Levels 1-2?
Shadesmo
When I am not near a supercharger, I would like to know which charger is the best option for both 110V and 240V. Many of my friends are semi-offgrid and have 110v solar panels, and a few of them even have 220/240V outlets that I can plug into. Looking for some feedback on whether there is a better or more universal mobile charger; the Tesla brand seems to fit my needs.
Many thanks
A couple of the adapters needed to use the Tesla Mobile connector are in my possession. A 120VAC 15amp and a 240VAC 50amp are provided (the mobile connector requires 32amps anyhow). Both the 120VAC and 240VAC 20amp adapters were also bought by me. They can be quickly and easily replaced; resetting the Mobile Connector to a different voltage or amperage is not required. Apparently, some of the less expensive models rely on you to adjust the settings correctly; however, I cannot verify this.
I have them all in my trunk right now, along with the Mobile Connector. Since it kept breaking for someone else, I was fortunate that someone offered me their Wall Connector for free. I think the reason it hasn't failed on me once is because I've only set it to 20 amps, whereas he may have had it set to 48 amps.
Tesla was the source of the two extra adapters I purchased. Why? Because, at the time, they were the most affordable option for me to buy them. It was more expensive than a brand new Tesla, even when listed as "used" on eBay.
It is expected that you possess the Mobile Connector, as well as adapters for 120VAC 15AMP and 240VAC 50AMP, given that your vehicle is a 2026 Model Y.
Is your Model Y here yet? Or are you still waiting for the VIN and/or delivery date after placing the order?
The two.
You can buy a bundle of adapters from Tesla or buy them separately.
In the event that you require an adapter to plug into an outlet that is not covered by Tesla, there are third parties that offer them for sale (for example, EVSE Adapters).
No matter what kind of adapter plug you might need, Tesla charge cords are the best. Nobody knows how to make a problem-free product like Tesla, so I wouldn't even think about using an aftermarket cord or plug.
