depofly Posted 3 hours ago Share Posted 3 hours ago Level 4 Niro 72-plate HEV. The wife stepped out in her Nero hairstyle today. Upon returning to the Nero, the key fob failed to unlock it. same outcome, no matter how many times I try. The 'connect' app let me access the car after she called, although at first it would only open the trunk. The doors finally unlocked when I re-locked and unlocked them a second time, however the mirrors remained closed. Upon entering, the vehicle started automatically, without the need to use the 12v button or anything of the like. Is anyone else having this problem and knows what happened or how to repair it? Many thanks Link to comment Share on other sites More sharing options...
PopeyeR Posted 3 hours ago Share Posted 3 hours ago Swap out the key fob's battery. Link to comment Share on other sites More sharing options...
Samuraisaint Posted 3 hours ago Share Posted 3 hours ago Without fail, I avoid this problem by replacing the batteries in my key fob every two years. Use your spare key instead, but keep in mind that it will also drain the battery even when not in use. Link to comment Share on other sites More sharing options...
tr4s Posted 3 hours ago Share Posted 3 hours ago The actual key that is concealed in the key fob can always be used to open the vehicle. Link to comment Share on other sites More sharing options...
HolyRoach Posted 3 hours ago Share Posted 3 hours ago If the fob battery is low, then something is wrong. If the vehicle is reacting to the connect app, it's quite unlikely that the problem is with the 12V system. Link to comment Share on other sites More sharing options...
