Nekomp Posted 56 minutes ago Share Posted 56 minutes ago Thankfully, a replacement engine—a 2 litre 1987 BMW straight six from a 5 series—is now available for purchase in place of the original engine in a Bristol. Any feedback you have regarding the engine would be much appreciated. A high-pressure pump and a return line to the tank are likely necessities due to the fuel injection system. The transmission looks to be automatic and is likewise made by BMW. What I want to know is if the ECU (which is also apparent in the pictures) need data from the speedo because I can make out an instrument binnacle. On the other hand, does it trigger the rev counter? Additionally, I'm assuming it's fuel, but I should probably check with the seller to be sure. I take it the ECU is where you can adjust the settings, right? Lightweight and aerodynamic, the original automobile didn't require a lot of power. Also, it has drum brakes! I would be very grateful for any feedback you could provide. Link to comment Share on other sites More sharing options...
Kiddokt Posted 56 minutes ago Share Posted 56 minutes ago One of two Bosch injection systems—the Motronic (129 bhp) or the LE-Jetronic Fuel Injection (125 bhp)—could be powering that M20. If you need help tuning, go at BWChipTune; it involves changing the chip. Link to comment Share on other sites More sharing options...
Nekomp Posted 55 minutes ago Author Share Posted 55 minutes ago It would be perfect for the power figures, thank you. Up front, the BMW/Bristol had 85 horsepower. Surely the M20 was an effective engine back then? To demonstrate their smoothness, I remember seeing ads with a house of cards erected on the camera cover. Link to comment Share on other sites More sharing options...
Grundysp Posted 55 minutes ago Share Posted 55 minutes ago If cared for properly, these will last forever; however, the later Motronic injection is the better choice due to its superior technology and dependability. Make sure the cooling system is in good working order; otherwise, the alloy head will be goosed, thus it's best to stick to the service schedule from the E30 and E34. Link to comment Share on other sites More sharing options...
Nekomp Posted 54 minutes ago Author Share Posted 54 minutes ago 🤩😍🤩 Link to comment Share on other sites More sharing options...
