Inspirli Posted 4 hours ago Share Posted 4 hours ago I'm a bit worried about this 330d 184hp car since it won't start. With the ignition on, I can hear a loud buzzing sound coming from the fuel pump under the hood, and I can see petrol running to the Hffp. Someone has torn out the glove box and opened the fuse box, and there's another one under the hood. The person from whom I got it said that it may be the ecu, but I'm not sure. My codes range from 1260 to 1E00. Thanks in advance for any guidance you may provide! Link to comment Share on other sites More sharing options...
Starat Posted 4 hours ago Share Posted 4 hours ago A low fuel pressure signal could be shown if the saddle tank's lift pump fails. Link to comment Share on other sites More sharing options...
Starat Posted 4 hours ago Share Posted 4 hours ago It may be due to insufficient battery power if there is no CAN-bus. Link to comment Share on other sites More sharing options...
Inspirli Posted 4 hours ago Author Share Posted 4 hours ago I will get it back up and running in a few days, examine the live data, and see if any more codes pop up; I think I eliminated some of them. Link to comment Share on other sites More sharing options...
Markwe Posted 4 hours ago Share Posted 4 hours ago If it runs for a few seconds on brake cleaner or easy start, then fuel hunger is the problem. It was only a notion. Link to comment Share on other sites More sharing options...
