Notef Posted March 11 Share Posted March 11 Last week, the traction control and check engine lights came on. I went to Autozone to get some codes read, and they shared P2401 and a few of others (all having to do with emissions). I replaced the gas cap, put it on, and gave it a spin, but it still wouldn't start. After that, I disconnected the negative battery terminal for 10 minutes to force a hard reset, and the lights stopped flashing. Following it, the idling was subpar, and it would occasionally die when I pressed the brakes to halt. I discovered that these automobiles require a few minutes of idling before they can retrain themselves, so I might have to leave it running at idle for that. That fixed it; for the next two days, I had no problems with the lights. Nonetheless, both lights turned back on today. Is anyone else familiar with this or has any thoughts about what might be happening? Perhaps you should clean the MAF sensor or the throttle body; I saw that mentioned somewhere. Link to comment Share on other sites More sharing options...
Radiantecon Posted March 11 Share Posted March 11 To learn more about P2401's diagnosis, watch the video below. Link to comment Share on other sites More sharing options...
Radiantecon Posted March 11 Share Posted March 11 Β Link to comment Share on other sites More sharing options...
Meltarb Posted March 11 Share Posted March 11 Gas cap replacement had no noticeable impact. A gas cap is designed to repair damaged or loose seals, therefore that's perfectly normal. By itself, a replacement cap won't fix an EVAP system that has a faulty solenoid or other component. Can you find a code scanner? How mechanically inclined are you? Link to comment Share on other sites More sharing options...
Notef Posted March 11 Author Share Posted March 11 I would say that I have taken an interest in doing some basic auto stuff on my own in the past year or two. Services such as oil changes, radiator drains and refills, brake pad replacements, and so on. Usually I take it to this auto parts store to get it read out since I don't have access to a code scanner. Link to comment Share on other sites More sharing options...
Meltarb Posted March 11 Share Posted March 11 Cut Power to the Battery (Hard Reset) If the warning lights are on, clearing the ECU will reset any stored fault codes and turn them off momentarily. Cons: The ECU will not remember any changes made to idle speed, throttle position, or fuel trim. When a Toyota's engine isn't drivable, the Check Engine (CEL) light and Traction Control (TRAC) light will often both come on at the same time. As soon as the electronic control unit detects abnormal engine power, such as misfiring or stalling, traction control can be disabled. P2401 + emission-related codes, most likely in the EVAP system, were the ones that AutoZone used to provide. Failed EVAP Vent Solenoid/Purge Valve A malfunctioning vent solenoid is the source of the P2401 code. Rough idling and stalling can be caused by a blocked purge valve. Steam Leaks These symptoms can be caused by any broken hose that connects the EVAP system to the intake manifold or the throttle body. Restored MAF sensor Instead of carb cleaner, use the correct MAF cleaner. Thoroughly scrub the throttle body Specifically, the plate and the passive air spaces around it. Evaluate components of EVAP Vent solenoid and purge valve operation. Look for breaks or separations in the hoses. To find vacuum leaks, while the engine is idle, spray carb cleaner around the hoses; if the RPM changes, the leak is located. Allow the vehicle to idle for ten to fifteen minutes after cleaning so it can retrain itself on the proper throttle and idle positions. Link to comment Share on other sites More sharing options...
Notef Posted March 11 Author Share Posted March 11 Your thorough explanation is much appreciated. I think I've finished planning my weekend project π Link to comment Share on other sites More sharing options...
