Videoman Posted January 29 Share Posted January 29 E350d Coupe C207 from 2016. Multiple instances of the warning "Collision prevention assist plus inoperative" have occurred; after scanning the vehicle with iCarsoft, the error code B21DE71 was returned. Due to a clogged actuator and a faulty relay, the Additional Battery is not functioning properly. After I reset it, it keeps popping back up at random. I will verify it, but the primary battery seems to be in fine shape. The auxiliary battery, on the other hand, was replaced with a real one around three years ago. I saw the notice "Auxiliary battery malfunction" the last time the backup battery stopped working. Using Google and the extra battery relay, we were able to locate the component number A0009822023. I need to know whether the auxiliary battery is okay, where to find the relay, and if they are a direct swap. Does the A0009822023 relay work with all Mercedes models? I've seen ads for ones that seem to be model-specific. Is anybody else familiar with this issue? Much obliged. Link to comment Share on other sites More sharing options...
Cincoon Posted January 29 Share Posted January 29 Hi there, It should be easy for you to replace the relay, which is located in the fuse box. Link to comment Share on other sites More sharing options...
Starat Posted January 29 Share Posted January 29 When this happens on my W205, it's typically because of the radar sensor or the wiring around it in the grill. Link to comment Share on other sites More sharing options...
Anabroo Posted January 29 Share Posted January 29 Verify its continued presence..... Link to comment Share on other sites More sharing options...
Mezuzzi Posted January 29 Share Posted January 29 ^^ They often "go walkabout" (often in the middle of the night) Link to comment Share on other sites More sharing options...
Mezuzzi Posted January 29 Share Posted January 29 πππ Link to comment Share on other sites More sharing options...
