TigerDrummer Posted 1 hour ago Share Posted 1 hour ago Has anyone experienced this? I have seen that it could be attributed to various factors; nevertheless, are there any prevalent issues? Link to comment Share on other sites More sharing options...
rauman Posted 1 hour ago Share Posted 1 hour ago Photographic evidence or it is unsubstantiated... Link to comment Share on other sites More sharing options...
Lemmand Posted 1 hour ago Share Posted 1 hour ago Consult the guidebook for the cluster display, which should provide the necessary information. Alternatively, as previously mentioned, a photograph would be beneficial. Link to comment Share on other sites More sharing options...
NightHawk47 Posted 1 hour ago Share Posted 1 hour ago The "very clever Mercedes-Me" may be alerting you that Christmas is approaching and that you need to get the remaining gifts. The Star signifies the forthcoming event. The purple square symbolises a gift-wrapped package. The demarcation between them is the chronology. Β Link to comment Share on other sites More sharing options...
BrambleBurt Posted 1 hour ago Share Posted 1 hour ago Artificial Intelligence proposes this. The purple square including a vertical line and a star symbol (which manifests as a purple vertical line and a star on the display) signifies a sensor or electronic control unit alert in your Mercedes W205. This is a generic alert, frequently associated with a malfunction in a particular system, and it is generally accompanied by an additional message on the dashboard that delineates the precise issue. Proposed Measures Verify for an associated message: The primary dashboard interface will probably exhibit language (e.g., "Inoperative", "Refer to Owner's Manual") elucidating the particular system experiencing a malfunction (e.g., Active Brake Assist, ESP, or a designated sensor). Reinitiate the vehicle. Occasionally, the problem may stem from a transient electronic malfunction that can be rectified by powering down the vehicle, removing the key for around 30 seconds, and thereafter restarting the engine. Exercise vigilance while driving: This indicator, when yellow or purple, indicates caution rather than an immediate red-level safety danger, allowing you to proceed to a safe place or an authorised repair facility. Seek the assistance of a technician: Due to the symbol's ambiguity, a diagnostic scan tool (OBD-II scanner) is required to ascertain the exact error code and root cause. Link to comment Share on other sites More sharing options...
Maidaser Posted 1 hour ago Share Posted 1 hour ago Does it appear as such? Link to comment Share on other sites More sharing options...
Maidaser Posted 1 hour ago Share Posted 1 hour ago Link to comment Share on other sites More sharing options...
BrambleBurt Posted 1 hour ago Share Posted 1 hour ago I recognised the familiarity; it has prompted my recollection. It appears that AI still has considerable progress to make. Link to comment Share on other sites More sharing options...
Lemmand Posted 1 hour ago Share Posted 1 hour ago π« Link to comment Share on other sites More sharing options...
Lemmand Posted 1 hour ago Share Posted 1 hour ago π Link to comment Share on other sites More sharing options...
