TigerDrummer Posted December 17, 2025 Share Posted December 17, 2025 Has anyone experienced this? I have seen that it could be attributed to various factors; nevertheless, are there any prevalent issues? Link to comment Share on other sites More sharing options...
rauman Posted December 17, 2025 Share Posted December 17, 2025 Photographic evidence or it is unsubstantiated... Link to comment Share on other sites More sharing options...
Lemmand Posted December 17, 2025 Share Posted December 17, 2025 Consult the guidebook for the cluster display, which should provide the necessary information. Alternatively, as previously mentioned, a photograph would be beneficial. Link to comment Share on other sites More sharing options...
NightHawk47 Posted December 17, 2025 Share Posted December 17, 2025 The "very clever Mercedes-Me" may be alerting you that Christmas is approaching and that you need to get the remaining gifts. The Star signifies the forthcoming event. The purple square symbolises a gift-wrapped package. The demarcation between them is the chronology. Β Link to comment Share on other sites More sharing options...
BrambleBurt Posted December 17, 2025 Share Posted December 17, 2025 Artificial Intelligence proposes this. The purple square including a vertical line and a star symbol (which manifests as a purple vertical line and a star on the display) signifies a sensor or electronic control unit alert in your Mercedes W205. This is a generic alert, frequently associated with a malfunction in a particular system, and it is generally accompanied by an additional message on the dashboard that delineates the precise issue. Proposed Measures Verify for an associated message: The primary dashboard interface will probably exhibit language (e.g., "Inoperative", "Refer to Owner's Manual") elucidating the particular system experiencing a malfunction (e.g., Active Brake Assist, ESP, or a designated sensor). Reinitiate the vehicle. Occasionally, the problem may stem from a transient electronic malfunction that can be rectified by powering down the vehicle, removing the key for around 30 seconds, and thereafter restarting the engine. Exercise vigilance while driving: This indicator, when yellow or purple, indicates caution rather than an immediate red-level safety danger, allowing you to proceed to a safe place or an authorised repair facility. Seek the assistance of a technician: Due to the symbol's ambiguity, a diagnostic scan tool (OBD-II scanner) is required to ascertain the exact error code and root cause. Link to comment Share on other sites More sharing options...
Maidaser Posted December 17, 2025 Share Posted December 17, 2025 Does it appear as such? Link to comment Share on other sites More sharing options...
Maidaser Posted December 17, 2025 Share Posted December 17, 2025 Link to comment Share on other sites More sharing options...
BrambleBurt Posted December 17, 2025 Share Posted December 17, 2025 I recognised the familiarity; it has prompted my recollection. It appears that AI still has considerable progress to make. Link to comment Share on other sites More sharing options...
Lemmand Posted December 17, 2025 Share Posted December 17, 2025 π« Link to comment Share on other sites More sharing options...
Lemmand Posted December 17, 2025 Share Posted December 17, 2025 π Link to comment Share on other sites More sharing options...
