CrawlerTagz Posted December 3 Share Posted December 3 I am experiencing cold starting difficulties and have recently replaced the glow plugs with four new NGK units. The battery is brand new. I evaluated the old ones on the bench, and just two illuminated. Two were ineffective. The engine starts more effectively after I installed the replacement components; yet, it remains hesitant and necessitated prolonged cranking this morning at 6°C. I wish to identify the issue utilising a scanning tool; however, which one is assured to be compatible with my year and model? Link to comment Share on other sites More sharing options...
Kenjibb Posted December 3 Share Posted December 3 It may be beneficial to install a new glow plug relay to determine whether this resolves the issue. Although it will perform direct-to-consumer testing, an oscilloscope is required, particularly if you have already addressed the glow plugs; this is the next probable issue to consider. Link to comment Share on other sites More sharing options...
Kenjibb Posted December 3 Share Posted December 3 If you require a device that exceeds Peugeot's capabilities, the LAUNCH X431 PRO appears to be compatible with Peugeot. Additional factors may include issues with air intake or hoover lines allowing air ingress. In diagnostics, this would be interpreted as positive trim at idle; conversely, it should have negative fuel trim. Link to comment Share on other sites More sharing options...
CrawlerTagz Posted December 3 Author Share Posted December 3 I am considering installing a new light plug relay. I will examine the pricing. They appear to be simple to install. Link to comment Share on other sites More sharing options...
Darthilli Posted December 3 Share Posted December 3 In comparison to glow plugs, this is among the simplest procedures for replacing components. Link to comment Share on other sites More sharing options...
