RicketyRick Posted November 11 Share Posted November 11 I appear to be posting excessively for my preference. Essentially, my partner is experiencing a power steering problem that is intermittent; it manifests primarily during slow speeds and steep turns. At times, the issue persists, while at other times, it resolves itself. No codes are stored on the computer either. Her explanation is: "It indicates that there are no codes, and the warning appears when the vehicle is moving slowly and I am making a sharp turn, or when I have just started the car." Assistance is welcomed. The vehicle is a 2010 BMW 320d Cabriolet, which I believe is equipped with electronic power steering. Link to comment Share on other sites More sharing options...
DolSquirrel Posted November 11 Share Posted November 11 Typically, when an alternator fails to provide sufficient power, the power steering system ceases to function. Link to comment Share on other sites More sharing options...
RicketyRick Posted November 11 Author Share Posted November 11 I believe the alternator is functioning adequately; nevertheless, I will do a test on it either tomorrow or Wednesday. If the alternator is indeed satisfactory, do you have any suggestions regarding the potential issue? Link to comment Share on other sites More sharing options...
Uneripty Posted November 11 Share Posted November 11 It is probable that the battery has deteriorated, if the illuminated indicator is orange rather than red. At low revolutions and with the alternator not operating at full capacity, rapidly twisting the steering wheel causes the power steering system to draw from the battery for assistance. If the battery is degraded, this may temporarily illuminate the warning light. There is no cause for concern; however, a new winter battery or a complete maintenance charge will likely resolve the issue. Link to comment Share on other sites More sharing options...
RicketyRick Posted November 11 Author Share Posted November 11 I replaced the battery last week with a new one and registered it as well. The BMW and all associated technology are functioning well. What voltage should I expect to observe on the battery during charging? What constitutes adequacy for the vehicle, essentially? Link to comment Share on other sites More sharing options...
RicketyRick Posted November 11 Author Share Posted November 11 🫠Link to comment Share on other sites More sharing options...
