NotePapa Posted November 7, 2025 Share Posted November 7, 2025 I am thoroughly exasperated with the potholes in this area, having irreparably ruined three of my Mini's 17-inch alloy wheels in the past year. These low-profile tires possess minimal rubber between the road and the rim, making wear unavoidable. Is there an issue with accommodating 16-inch or even 15-inch wheels, as they would likely endure local road conditions better? Feedback? Link to comment Share on other sites More sharing options...
HeadlinesQuick Posted November 7, 2025 Share Posted November 7, 2025 I installed these 16-inch wheels on a Mini Cooper S, which typically comes with 17-inch wheels. Fifteen-inch wheels are incompatible with a Cooper S because to the oversized braking discs and callipers. A smaller model, such as a micro version, may accommodate a 15-inch size. It enhanced comfort. Link to comment Share on other sites More sharing options...
NotePapa Posted November 7, 2025 Author Share Posted November 7, 2025 Superb HeadlinesThank you for your prompt response. Did you encounter any issues with the speedometer? Does the circumference remain constant with smaller rims and larger tires? Link to comment Share on other sites More sharing options...
HeadlinesQuick Posted November 7, 2025 Share Posted November 7, 2025 I believe that due to the tire's deeper sidewall, it is essentially equivalent. I would not be concerned about that, as I believe it does not significantly impact most exchanges. Link to comment Share on other sites More sharing options...
Squirrrel Posted November 7, 2025 Share Posted November 7, 2025 My third-generation Clubman is equipped with tire pressure sensors in the wheels, which are available in various colours to indicate different fitments. In contrast, pre-generation models, like yours, utilise ABS rings and sensors; a deflated tire rotates less than an inflated one, which the ABS detects. The advantage for you is that you can install any wheel you desire and perform a reset of the tire pressure warning, allowing the system to recognise the change. As a general guideline for speedo Link to comment Share on other sites More sharing options...
TheCreakyChair Posted November 7, 2025 Share Posted November 7, 2025 I replaced the 17-inch wheels on my Cooper S with 16-inch ones, which provide increased sidewall on the tires and significantly enhance comfort. I am now considering replacing the dampers and springs to further improve ride quality due to the condition of the roads. Link to comment Share on other sites More sharing options...
NotePapa Posted November 7, 2025 Author Share Posted November 7, 2025 I have now installed 16-inch alloy wheels, and the improvement in noise levels and comfort is significant - I am very pleased. I was rather concerned about speedometer calibration; however, while the speedometer indicates 40 mph, the satnav displays 37 mph, which I consider acceptable. At least the situation is not reversed, with the speedometer indicating a slower speed than the satnav. Link to comment Share on other sites More sharing options...
TheCreakyChair Posted November 7, 2025 Share Posted November 7, 2025 Can anyone provide insights on the value of installing adjustable coilovers or the potential issues they may cause? Has anyone had experience with their installation? Link to comment Share on other sites More sharing options...
