Issue with n47 boost
Darthilli
Hello, I am experiencing an issue with Mini; maybe someone might provide a solution.
I own a Mini Countryman 2.0d N47, which lacks sufficient torque until around 2,200 RPM. The real boost is much lower than the quoted value. That is likely the explanation. However, the primary issue is the absence of mistakes. DPF removed, EGR also eliminated and reprogrammed accordingly. Perhaps someone might recommend where to search. While replacing the chain, the technician inspected the turbo and confirmed it was functioning properly. However, it exhibits sluggish acceleration. Inspected the mass airflow sensor, performed cleaning, tested other sensors without success, and conducted a leak test, which also yielded no results. almost devoid of responses. Thank you.
Greetings, I acquired it in this condition almost four years ago; nonetheless, my wife was the one using the vehicle. Upon purchase, I opted for carbon cleaning. The technician saw that the EGR had been blanked off with a gasket, indicating it had been programmed out prior to my acquisition. Additionally, when replacing the timing chain and inspecting the turbo, we discovered that the DPF was clogged, therefore it was subsequently removed. However, the vehicle exhibits very low torque until reaching 2,000 RPM. I attempted to restore the vehicle to its normal settings, and then programmed off the DPF and EGR, but this did not provide any improvement.
I conducted a vacuum smoke test, and everything seems OK; however, it only generates 1 bar of pressure smoke. Upon reviewing the log, I saw that at around 2.2k RPM, the real boost aligns with the intended value. Prior to this, at around 1.7k RPM, the specified boost is approximately 1 bar, but the actual boost ranges from 0.5 to 0.6 bar.
