DolSquirrel Posted August 29, 2025 Share Posted August 29, 2025 Hello, I have lately had a misfire under aggressive acceleration. I have acquired a new map sensor and will install it later; I will inform you of the results. Link to comment Share on other sites More sharing options...
DolSquirrel Posted August 29, 2025 Author Share Posted August 29, 2025 That was unproductive; when installing the sensor, two problems regarding air intake were indicated. I reverted to the previous sensor, and the dashboard light has extinguished. I have addressed all other components, including spark plugs and coils. I suppose I must just accept the situation. Link to comment Share on other sites More sharing options...
rauman Posted August 29, 2025 Share Posted August 29, 2025 I own the same vehicle; which sensor did you purchase? I acquired mine from Autodoc and have had no problems with it. Have you performed a scan using an OBDII device? Link to comment Share on other sites More sharing options...
DolSquirrel Posted August 29, 2025 Author Share Posted August 29, 2025 I acquired a map sensor 39300/84400 from eBay. Upon scanning with OBD, I detected two errors related to air pressure. Consequently, I reinstalled the original sensor, resulting in no failures on the scanner. Link to comment Share on other sites More sharing options...
Automan Posted August 29, 2025 Share Posted August 29, 2025 Did you do a soft reset to synchronize with the change? I am astonished that you encountered issues; I am certain that it is the sensor I changed shortly after purchasing my GT. It resolved my problems and did not produce any errors. Link to comment Share on other sites More sharing options...
Nekomp Posted August 29, 2025 Share Posted August 29, 2025 It is fairly usual for non-genuine parts to have difficulties in clearing codes. I replaced a coil due to a misfire, which resolved the issue, but I was unable to extinguish the warning light. Upon installing a genuine coil, the problem was rectified. Link to comment Share on other sites More sharing options...
