HushedGamer Posted June 26 Share Posted June 26 Greetings everyone, I changed all four discs on my 2011 C180 due to significant wear, but retained the pads since they were installed by the previous owner and were essentially new. I have acclimated them, nevertheless they continue to emit a little squeak under braking, although not consistently. I believe the brake discs are of inferior quality (the name is unknown since the garage installed them for a total of £250), and I have read online that low-cost discs and pads tend to produce more squeaking sounds. Should I write off that expense and invest in quality pads and discs all around, while also replacing the dust shields concurrently? I want to do this independently with assistance; what instruments will I need? Link to comment Share on other sites More sharing options...
RumbleRex Posted June 26 Share Posted June 26 In my experience, the squeaking of new brakes is mostly attributable to inadequate fitting. Anti-squeal shims may be absent (if relevant), inadequate cleaning and re-lubrication of the contact points for the pads are issues (do not use copper grease here, as it is an anti-seize, not a lubricant; ceramic grease is appropriate, and red rubber grease should be applied to the boots and new seals if installed). Ensure there is no oil on the rear of the pads; copper is OK in this area. If following Brembo standards, the sliding pins should not be left dusty or rusted. The pads are too tight, causing them to remain in contact with the disc post-application, resulting in adhesion and insufficient movement away from the disc. This issue is often attributed to an overly thick coating of paint and a snug fit from end to end. It may be readily remedied with a minor file. Additionally, failing to adhere to the break-in instructions provided by pad manufacturers, such as EBC Yellow Stuff, may include unconventional break-in procedures. Typically, inexpensive discs do not induce squeaking; they are just a mass of rotating cast iron. The primary concern with low-quality discs is their tendency to distort after a short period or experience rapid corrosion on the elevated surfaces and hub owing to inadequate corrosion resistance. Link to comment Share on other sites More sharing options...
Uneripty Posted June 26 Share Posted June 26 £250 for that service is very inexpensive, prompting inquiries about the time used in the task, such as cleaning, wire brushing, and the application of appropriate lubricant. I would not use old pads on new discs; nevertheless, I would employ fresh pads on utilized discs. Link to comment Share on other sites More sharing options...
