Charging connection
Preedom
Have you reviewed your settings in the Charge Connector section? There are choices to have the connector secured during charging, secured when attached, or set to "off".
Navigate to Settings on your infotainment display, then choose EV Settings. You will find the settings for the charge lock connector there.
