Run-flat tires or conventional tires?
DolSquirrel
I possess a 3 Series Touring M Sport and require the replacement of three tires. They are presently run-flat tires; however, given the condition of the roads in my area and generally, I am considering replacing all four with conventional tires. Regrettably, I am constrained by a limited budget, hence I will not be purchasing premium tires. I am seeking ideas to determine whether to prioritise the safety benefits of run-flat tires or the driving quality of conventional tires. I believe my suspension and wheels are deteriorating with each unavoidable pothole I encounter.
Thank you.
I have already converted two 6 series vehicles from run-flat tires to conventional tires, resulting in an improved ride quality without any significant drawbacks, except from the potential for punctures and the necessity of using sealant and a pump.
Salutations
I prefer standard tires.
Examine the Camskills website and apply the filter for 'A.' Wet grip rating
Examine the exceptional traction of Uniroyal Rainsport in wet conditions.
