Shmoein Posted February 14, 2025 Share Posted February 14, 2025 Greetings, Could someone please inform me of the position of the crankshaft sensor on the 2008 B200 automatic vehicle? I have removed the air filter housing and cannot locate a replacement. Receiving code P0016. Link to comment Share on other sites More sharing options...
AmericaMonster Posted February 14, 2025 Share Posted February 14, 2025 It will be positioned much lower than the air filter housing. The sensors are often located at the junction of the engine and gearbox. Typically at a really uncomfortable location! Link to comment Share on other sites More sharing options...
BizarreBleak Posted February 14, 2025 Share Posted February 14, 2025 This is the CPS for an M113 V8, identical to the V6 variant and several others. Measures the pulses from the starting motor ring, which is affixed directly to the crankshaft. Are you maybe seeking the camshaft sensor? Link to comment Share on other sites More sharing options...
BizarreBleak Posted February 14, 2025 Share Posted February 14, 2025 Link to comment Share on other sites More sharing options...
Captiva Posted February 14, 2025 Share Posted February 14, 2025 Petrol B200, Item 20, as shown in the diagram below. Link to comment Share on other sites More sharing options...
Captiva Posted February 14, 2025 Share Posted February 14, 2025 https://webautocats.com/epc/mercedes/1/m/266960/64j/15/120/?fg=24523366D Link to comment Share on other sites More sharing options...
Captiva Posted February 14, 2025 Share Posted February 14, 2025 Diesel B200Cdi, Item 70 in the diagram below. Link to comment Share on other sites More sharing options...
Captiva Posted February 14, 2025 Share Posted February 14, 2025 https://webautocats.com/epc/mercedes/1/m/640941/63g/15/105/?fg=24520866D Link to comment Share on other sites More sharing options...
Captiva Posted February 14, 2025 Share Posted February 14, 2025 Please provide the first six digits of your VIN if you own a different model. Link to comment Share on other sites More sharing options...
BizarreBleak Posted February 14, 2025 Share Posted February 14, 2025 It seems that you need a camshaft sensor. Position 40 in the first diagram. Link to comment Share on other sites More sharing options...
