Mezuzzi Posted January 22 Share Posted January 22 Greetings. Today, I detected a burning odour like rubber. Upon opening the hood, I saw smoke emanating from the oil cap. Pale grey fog. Upon closer examination, I saw that the coolant tank (black plastic device) was warm to the touch. The coolant reservoir is at capacity. Has anybody else had this difficulty, or can someone clarify whether there is a problem? Link to comment Share on other sites More sharing options...
Mezuzzi Posted January 22 Author Share Posted January 22 LOL it is heated to the touch. The outside of the coolant tank feels hot to the touch. Link to comment Share on other sites More sharing options...
Istairde Posted January 22 Share Posted January 22 What is the temperature of your coolant? Is your vehicle displaying any warning indicators or entering limp mode? Is it possible that the smoke originates from spilt oil rather than the oil filler cap itself? Link to comment Share on other sites More sharing options...
Mezuzzi Posted January 22 Author Share Posted January 22 I do not know the temperature. No indicator lights Absence of Limp mode. The oil cap of the car has not been removed for 11 months. The exterior surface of the coolant tank seems unusually hot, a sensation I have not before experienced, leading me to question its normalcy. I suspect it needs an oil change, since almost a year has elapsed. Consequently, if the oil level is low, the coolant temperature will increase. The hazy vapour emanating from the top may be dampness. There are no concerns with the automobile save for a burning rubber smell and the heated coolant reservoir. It may be the radiator. I want reassurance or confirmation of the normalcy of this situation. Link to comment Share on other sites More sharing options...
Istairde Posted January 22 Share Posted January 22 Verify the oil level using the dipstick and see whether smoke emanates from the dipstick opening while the engine is operational. The oil filler cap must be securely shut to prevent any smoke from escaping. Verify your coolant temperature via the concealed menu; seek on YouTube for instructions on how to do this. Does your engine fan activate when you use the air conditioning? Link to comment Share on other sites More sharing options...
Mezuzzi Posted January 22 Author Share Posted January 22 I have just seen a YouTube video on the coolant technique. Summing numerical values, among other tasks. Impressive. No smoke emanating from the dipstick. I will inspect the engine fan presently. I appreciate your attention about this matter. Thank you. Link to comment Share on other sites More sharing options...
Mezuzzi Posted January 22 Author Share Posted January 22 The blades are rotating on the radiator fan. Link to comment Share on other sites More sharing options...
Istairde Posted January 22 Share Posted January 22 If your coolant temperature is accurate, with the hidden menu stabilising at about 88 degrees Celsius when heated, there is likely no need for concern. Link to comment Share on other sites More sharing options...
