The gearbox required six sump dumps.
Patagil
In April, I performed three sump dumps on my ASIN 6-speed automatic gearbox with 90,000 miles, and the fluid remained black. Nonetheless, there was a discernible improvement in the brightness and smoothness of the box. This was only a preventive maintenance activity; there were no issues with the box.
I let it to sit for a while to enable fluid circulation and performed three further sump dumps this weekend. September.
Only during the drainage of the sixth dump was the clear pink fluid clearly visible.
I was astonished by the number of attempts required to remove the most of the filth; nonetheless, if you are considering doing this task, prepare for six disposals.
I adjusted the fluid level to 53 degrees Celsius. Reset the oil deterioration counter and performed a gearbox reset.
There was once again a significant enhancement, making it seem much more like to a new vehicle.
Highly beneficial and quite simple once started.
It should provide a another 100,000 miles; however, I will likely replace it again in 50,000 miles. Uncertain expression.
It is my vehicle, and I understand that vintage automobiles benefit from proper maintenance. I completed the second PTU oil change; the first experience was unsatisfactory, but this time it was much improved.
Despite having it for four years, I really like it and cannot identify a better alternative, but the XC90 remains enticing.
Indeed, I share the same sentiment; nothing captivates me quite like my Evoque. I still have affection for it, however I acknowledge the need to change. I just began exploring Polestars and the new Volvo EX40, only to discover the considerable challenges associated with installing an electric charging station in my garage owing to the position of the electric meter cabinet. I may be able to use the Garage circuit on a 40A breaker; however, the neighbours have been informed that they can no longer use it too.
Indeed, electric vehicles provide an intriguing alternative; yet, in terms of long-term ownership, I am avoiding them owing to the restricted battery guarantees and exorbitant expenses associated with potential failures.
The one exception I have seen is Toyota, which offers a guarantee of up to 15 years on their batteries; however, their vehicles are somewhat unexciting.
