Darthilli Posted August 6, 2024 Share Posted August 6, 2024 (edited) I just acquired a 2004 R230 vehicle, and unfortunately, the Easypack system is not functioning properly. The first thing to investigate is the fuse, however the information page does not include details on the Easypack system. Does anybody have any individual ideas? Edited August 6, 2024 by Darthilli Link to comment Share on other sites More sharing options...
AmericaMonster Posted August 6, 2024 Share Posted August 6, 2024 An easypack refers to a kind of packaging that is designed to be simple and convenient to use. Link to comment Share on other sites More sharing options...
Darthilli Posted August 6, 2024 Author Share Posted August 6, 2024 I should have specified "Loadassist Easypack." It is a feature that enables you to slightly raise the stored roof while it is in the lowered position. Enhancing accessibility to the trunk space when the roof is stored. Link to comment Share on other sites More sharing options...
Mantelle Posted August 6, 2024 Share Posted August 6, 2024 Discovered this: https://www.benzworld.org/threads/malfunctioning-loading-assist-easy-pack.3028032/ Link to comment Share on other sites More sharing options...
AmericaMonster Posted August 6, 2024 Share Posted August 6, 2024 Make sure to elevate the boot to its maximum height. If it is not fully elevated, the simple pack function will not operate. Link to comment Share on other sites More sharing options...
Shmoein Posted August 6, 2024 Share Posted August 6, 2024 What is the procedure for activating it? I am curious whether the slot on my R171 SLK is as thin as an Argos brochure when the roof is down. I presume that it is only designated for SL, however I really hope that my assumption is incorrect. Link to comment Share on other sites More sharing options...
AmericaMonster Posted August 6, 2024 Share Posted August 6, 2024 On the r230, fully open the trunk and then click the red button. This will cause the roof to elevate, facilitating the loading process. To shut the roof, ensure that the separator is in the closed position and then hit the red button once again. Link to comment Share on other sites More sharing options...
Darthilli Posted August 6, 2024 Author Share Posted August 6, 2024 Negative! You are correct, I hope you like your 171. I just exchanged mine for the SL model. Link to comment Share on other sites More sharing options...
