Adv3nture Posted May 25, 2024 Share Posted May 25, 2024 Hello everyone, I would want to inquire whether the air conditioning performance of the CX90 has been enhanced compared to the previous generation CX-9, which was only marginally satisfactory. Is the compressor size and overall refrigeration unit on the CX90 more powerful than on the CX-9? The previous generation of the CX-9 was much less powerful compared to the original CX-9, which had a very cool and impressive performance. Link to comment Share on other sites More sharing options...
tr4s Posted May 25, 2024 Share Posted May 25, 2024 While I acknowledge that this may be a matter of personal opinion, I have experienced temperatures above 100 degrees Fahrenheit in Florida on many occasions without needing to use the air conditioning at its highest setting. I am content with it. Link to comment Share on other sites More sharing options...
Adv3nture Posted May 25, 2024 Author Share Posted May 25, 2024 Have you ever owned or driven a CX-9 in comparable hot conditions in order to make a comparison? The AC performance of the CX-9 has significantly declined from its previous generation in 2016 and beyond. Link to comment Share on other sites More sharing options...
tr4s Posted May 25, 2024 Share Posted May 25, 2024 Unfortunately, I am unable to do a comparison between the two options. Link to comment Share on other sites More sharing options...
Adv3nture Posted May 25, 2024 Author Share Posted May 25, 2024 Is it possible to verify if the size and power of the cooling system in the CX90 were enhanced compared to the CX9? Link to comment Share on other sites More sharing options...
depofly Posted May 25, 2024 Share Posted May 25, 2024 Having experienced both, I am able to discern the difference. The temperature of 90 degrees decreases more rapidly, particularly in the MHEV (uncertain about the PHEV). On the ninth iteration, they used the same compressor as the fifth iteration, resulting in a slightly decreased power output for the ninth iteration. While it is not inherently negative, one may discern a noticeable difference. The large windscreen of the 9 was not beneficial since it allowed excessive heat to enter. What significantly improved the situation on the 9 was the application of window tinting to the front windows (except the windscreen), thereby reducing the amount of heat entering the vehicle. Link to comment Share on other sites More sharing options...
PopeyeR Posted May 25, 2024 Share Posted May 25, 2024 Significantly improved throughout the 1990s. My Mazda CX9 required an excessively long time to generate heat and never achieved a very low temperature. Link to comment Share on other sites More sharing options...
tr4s Posted May 25, 2024 Share Posted May 25, 2024 Consider tinting the side windows with the appropriate shade, as recommended. Not all hues have sun filtering capabilities, just so you know. Link to comment Share on other sites More sharing options...
Adv3nture Posted May 25, 2024 Author Share Posted May 25, 2024 Thank you for the guidance. Link to comment Share on other sites More sharing options...
