Main Beam Fuses
Workerat
Hi, can someone provide the location of the primary beam fuses? Is there one for each side, 56AL and 56AR? The primary beam on the passenger side is not functioning, however it does operate when connected to the driver's side. Would much appreciate any assistance? Thank you.
I believe the issue is not connected to the fuse. Upon examining the wiring schematic for both standard and xenon lights, it is seen that the power supply is directed to the FRM (Footwell Module) before being distributed to the lights. Both sides have a shared basis, thus it is not that. It is possible that there is an exposed wire or corrosion on one of the connections.
