Workerat Posted March 11, 2024 Share Posted March 11, 2024 Hi, can someone provide the location of the primary beam fuses? Is there one for each side, 56AL and 56AR? The primary beam on the passenger side is not functioning, however it does operate when connected to the driver's side. Would much appreciate any assistance? Thank you. Link to comment Share on other sites More sharing options...
Maidaser Posted March 11, 2024 Share Posted March 11, 2024 The fuse locations may be found in the car's manual. I have now reviewed my autodata and it does not say anything about lights, just the washers for xenons. Link to comment Share on other sites More sharing options...
Workerat Posted March 11, 2024 Author Share Posted March 11, 2024 I have previously consulted the guidebook, which provides information on the location of the fuse boards, but does not specify the location of individual fuses. Link to comment Share on other sites More sharing options...
HeadlinesQuick Posted March 11, 2024 Share Posted March 11, 2024 I believe the issue is not connected to the fuse. Upon examining the wiring schematic for both standard and xenon lights, it is seen that the power supply is directed to the FRM (Footwell Module) before being distributed to the lights. Both sides have a shared basis, thus it is not that. It is possible that there is an exposed wire or corrosion on one of the connections. Link to comment Share on other sites More sharing options...
Workerat Posted March 11, 2024 Author Share Posted March 11, 2024 Thank you for your response. Could you please provide information on the specific location of these fuses so that I can disable them? Thank you. Link to comment Share on other sites More sharing options...
HeadlinesQuick Posted March 11, 2024 Share Posted March 11, 2024 The junction box is located on the right-hand side of the footwell. Both 40A and F52 and F53. Link to comment Share on other sites More sharing options...
Workerat Posted March 11, 2024 Author Share Posted March 11, 2024 Thank you for your assistance, HeadlinesQuick. I own a second-generation vehicle from the year 2011. Will this continue to be true? Thank you Link to comment Share on other sites More sharing options...
HeadlinesQuick Posted March 11, 2024 Share Posted March 11, 2024 After examining the Gen2 wiring schematics, I am certain that it should be the case (hopefully). Link to comment Share on other sites More sharing options...
Workerat Posted March 11, 2024 Author Share Posted March 11, 2024 Charming. Thank you, HeadlinesQuick. I appreciate it. ππ» Link to comment Share on other sites More sharing options...
