Am I destroying my dde?
Banman
A sequence of occurrences transpired in the following manner;
Make an effort to install a new stereo, discover a plethora of outdated aftermarket Parrott components concealed behind the dashboard, which I promptly remove. Install the stereo, but the ihka unit is nonfunctional; all other components are operational at this stage. Return to the area and attempt to identify the issue with the air conditioning panel - it fails to illuminate. Examine a batch of fuses and cease activities for the evening.
The following morning, I am certain I hear a relay click as I walk by the vehicle early on, but I do not have the opportunity to inspect it until late morning.
The vehicle fails to start, but the battery is depleted; therefore, I have connected it to a charger and anticipate that an EWS reset will be necessary, which I will attempt later. Even at 13 volts, the reset/store function fails to initiate it.
A recurring error reappears instantly after being cleared; 46D1.
The internet indicates that this is an internal error within the dde. That appears rather dreadful.
After a brief period and an effort to initiate, it will typically, though not invariably, start, followed by several additional errors: 4120 46c0 4a03.
Regrettably, I did not document several others today.
All seemingly connected to the energy surrounding the dde or the intellect contained within it.
Following several efforts via inpa to recalibrate the ews, it frequently fails to establish communication with the dde entirely. Inpa simply fails to perceive it.
I require a rational diagnosis instead of making random guesses. It appears that, logically, since it was functioning (excluding the climate control panel) prior to my removal of the fuses, the act of pulling and reinserting the fuses might have disturbed the electronics.
At mid-morning, I acquiesced and detached the negative battery terminal, leaving it disconnected. It resisted for a time, securing the doors and emitting beeping sounds intermittently before falling silent. This evening, I reattached the battery as I intended to close the trunk for the nite. It is currently connected to a trickle charger, so I anticipate dedicating some time to it tomorrow.
Possess the BMW tools program suite. Primarily acquainted with inpa. However, I did manage to have the NCS specialist examine the VIN today. However, that is the extent of my progress on that matter.
What priorities should be assessed? Are there fuses and relays located in the engine compartment?
Intermittent INPA communication typically indicates an issue with the DDE's power or ground rather than a malfunctioning unit, and insufficient voltage can also trigger internal error codes. Prior to further EWS alignment, inspect the DDE relay within the engine bay electronics compartment and ensure that each removed fuse is reinstated in its original position, securely fitted.
The approximately one inch of water present in the dde case likely contributed to the issue. I have removed the residue from that side and will attempt to leave it open in the airing cupboard overnight - it appears improbable, yet it incurs no expense.
Alternatively, there exists a nearby establishment that will create a substitute for me.
The entire matter concerning the radio and fuses might have been a mere distraction.
Indeed, desiccating it proved ineffective. A substitute is en route, and I am optimistic about achieving successful coding.
In the interim, I will attempt to address the water infiltration and insufficient drainage. The failure occurred during a period of significant moisture, and the dde cubby evidently contained a substantial amount of water, with a small compartment halfway filled. It appears peculiar since the design does not seem unfavourable.
