Thenornpo Posted 28 minutes ago Share Posted 28 minutes ago Hey everyone - It seems like the automatic 5-speed gearbox in my 2009 S212 E220 has let a little air out. My mechanic discovered this this morning while getting ready to change the oil and filter in the gearbox, which was last done two years ago. Last year at this time, he changed the oil in the engine and failed to notice the leak. The gearbox oil level has only gone down "marginally," in his estimation; the sensor has not activated a warning light. What does this mean? Is it necessary to be concerned, or can I simply keep an eye on it? Who can I contact in the UK who is an expert in this field? I am located in the Midlands. I appreciate it. Link to comment Share on other sites More sharing options...
Micobe Posted 27 minutes ago Share Posted 27 minutes ago It appears to be an oil leak in the engine. It could be due to the plastic sump on your engine, which can sometimes warp slightly and eventually let water leak out? Without a doubt, that's motor oil, not anti-freeze. Link to comment Share on other sites More sharing options...
Thenornpo Posted 27 minutes ago Author Share Posted 27 minutes ago Even though the mechanic confirmed that the oil in the gearbox is red, I still don't see it. Okay, I'll go ahead and get a second opinion. Link to comment Share on other sites More sharing options...
Lovelyas Posted 24 minutes ago Share Posted 24 minutes ago I can't help but notice that side of the pilot bush. O ring failure and, I think, ATF transit up the loom are two of their well-known issues. My first step would be to search for signs of the source while cleaning the area with white spirit. Observing the pilot bush in particular. It will still smell like cat pee, but it will be black unless the ATF is brand new. Link to comment Share on other sites More sharing options...
Mindumer Posted 23 minutes ago Share Posted 23 minutes ago It is common for the big electrical connector, also known as the pilot bush, to leak. If this is the source, it's a cheap part to replace—about £25 from Mercedes. It has been a while since I had a vehicle with a five-speed gearbox, but I don't recall seeing any kind of warning for low fluid level. Link to comment Share on other sites More sharing options...
Liveek Posted 23 minutes ago Share Posted 23 minutes ago A leak from the pilot bush, the electrical connector on the side of the 5g box, is known to occur, as mentioned earlier. If you only replace the o ring, you run the danger of future problems caused by an electric connector contaminated with oil, so a new pilot push is usually the best solution. Assuming the mechanic is familiar with changing the AFT on this vehicle, he ought to be able to swap out the pilot bush as well. I fail to see the necessity for an MB specialist. Link to comment Share on other sites More sharing options...
Mututing Posted 23 minutes ago Share Posted 23 minutes ago It doesn't appear to be the pilot bushing; it's too far ahead. My first guess is a sump gasket or a seal on the back of the main crank, given the colour and placement. Link to comment Share on other sites More sharing options...
spartan Posted 22 minutes ago Share Posted 22 minutes ago After it's all swept up, its source should be readily apparent. Link to comment Share on other sites More sharing options...
