Strongspoi Posted 29 minutes ago Share Posted 29 minutes ago Hey everyone! I'm having some issues with my E350 cabriolet. The phone control from the wheel has stopped working, the eco stop start feature isn't working either, and the headlights seem to be pointing downwards with an orange tint when they're on full beam. Any suggestions? Can you think of anything? Link to comment Share on other sites More sharing options...
Videoman Posted 29 minutes ago Share Posted 29 minutes ago When the engine is turned on, what does the battery voltage read? Need to be a minimum of 14 volts. Consult an automotive electrician about the charging system if it's not enough. Link to comment Share on other sites More sharing options...
Strongspoi Posted 28 minutes ago Author Share Posted 28 minutes ago The alternator is maintaining a steady output of slightly less than 14 volts. Link to comment Share on other sites More sharing options...
Videoman Posted 28 minutes ago Share Posted 28 minutes ago Although slightly low, under 14 volts might be nothing more than a distraction. I'd take it to a professional mechanic or auto electrician to make sure the problem isn't with the charging or battery. Link to comment Share on other sites More sharing options...
