Mututing Posted 25 minutes ago Share Posted 25 minutes ago Introducing the 2023 Niro 3 HEV S-A. Because of the low pressure I noticed that the front offside tire pressure was showing as low on the dashboard display. After checking, I found out that it was only 1 PSI lower than the rest of the tires, so I decided to increase the pressure. All four tires' reported pressures are the same, but the warning light is still on and the telltale is highlighting the front offside tire (32). Do I need to take it to a mechanic to get the Telltale reset, or is it possible to do it myself? Link to comment Share on other sites More sharing options...
Mututing Posted 24 minutes ago Author Share Posted 24 minutes ago Amazon.co.uk : 2023 Niro Link to comment Share on other sites More sharing options...
Mututing Posted 24 minutes ago Author Share Posted 24 minutes ago https://www.amazon.co.uk/s/?search-alias=aps&field-keywords=Kia+Sportage+HEV Link to comment Share on other sites More sharing options...
Liveek Posted 24 minutes ago Share Posted 24 minutes ago Before readjusting the pressure to 32 psi, try driving for two or three miles with the affected wheel inflated to 38 psi to see if it resets. Link to comment Share on other sites More sharing options...
Mututing Posted 23 minutes ago Author Share Posted 23 minutes ago Excited to try it out and provide you with updates. Link to comment Share on other sites More sharing options...
Radiantecon Posted 23 minutes ago Share Posted 23 minutes ago Kia Niro EVs should have their front and rear tires inflated to 36 psi (2.5 bar). The tyre information sticker on the driver's side door pillar will confirm this exact figure. Link to comment Share on other sites More sharing options...
Banman Posted 21 minutes ago Share Posted 21 minutes ago Overinflation and subsequent restoration to the proper pressure is occasionally required, as I believe I read somewhere. Perhaps it's specific to the TPS sensor in question, or maybe they could become "a bit stuck"—I have no idea! My mind is racing with questions regarding TPS sensors (apologies for the tautology)... Does their useful life end after a certain number of years as a battery-operated device? Does the car's lifespan increase when it's at a standstill because they get a good night's sleep in it? It will soon be our soul's sixth year. Will it be necessary to replace all TPS sensors in the near future or in a few years? Should we just replace all four when one starts to fail, or would it be more efficient to do it all at once and save money? Do I really care if a regular tyre shop or a Kia service center replaces the sensors? Does installing a new TPS sensor on a Kia require any special magic? In most cases, would you rather have a new sensor or a different battery for the same sensor? (I assume they are seen as a one-time use item that requires a full replacement) Does the fact that not all TPS have the same accuracy and lifespan apply here? Link to comment Share on other sites More sharing options...
Liveek Posted 21 minutes ago Share Posted 21 minutes ago Detectors can be either direct or indirect. The ABS system includes an indirect sensor that receives its power from the vehicle. powered by a battery that, depending on usage, can last anywhere from five to ten years straight. When it's time to replace the direct, you can visit any tire shop that can do the job. The parts don't need to be authentic, but they will need to be programd to your car. I would replace all of them if I had the means to do so; that way, I would be covered for five years. However, if I were selling the car, I would just replace one. I went seven years without a TPMS problem with one of my earlier sportages. Link to comment Share on other sites More sharing options...
Liveek Posted 20 minutes ago Share Posted 20 minutes ago Tire Pressure Monitoring System TPMS, Solar Power Universal Wireless Car Alarm System with 4 External Sensors, LCD Real-time Display 4 Tires' Pressure & Temperature Alerts Ensure Safe Driving(Red) : Amazon.co.uk: Automotive Link to comment Share on other sites More sharing options...
Mututing Posted 19 minutes ago Author Share Posted 19 minutes ago Your thoughtful responses to my query are much appreciated. Following noblue's suggestion, I upped the pressure, and the issue disappeared. Much obliged. Link to comment Share on other sites More sharing options...
SlayNeo Posted 19 minutes ago Share Posted 19 minutes ago When I got new tires put on all around, the tyre shop employee insisted that the manufacturer sets the pressure at 38, which is completely false. On my Niro self-charging vehicle, you can see the pressure displayed on the dashboard; in the summer, it reads 38, but now that winter has arrived, it reads 33. As the tires warm up on a trip, they go up to 35, just like Formula One cars. I can guarantee that when summer rolls around, the pressure will return to 38 without any inflating. Link to comment Share on other sites More sharing options...
Liveek Posted 18 minutes ago Share Posted 18 minutes ago This is why you should inspect and possibly change your tires on a frequent basis, taking into account changes in weather and temperature. I have my suspicions that Kia knows best, even though the tyre fitter has the right to his opinion. If he didn't, they would be swamped with lawsuits. While pressure may be an issue in Formula One, I don't think it has much of an effect in the real world—the only real consequence being uneven tyre wear from consistently driving at high speeds. Link to comment Share on other sites More sharing options...
