TillyBytes Posted 27 minutes ago Share Posted 27 minutes ago Greetings, everyone! I am new to this forum and am currently struggling to diagnose a problem with a 2017 Grand Scenic. Continues to generate A consistent clutch switch signal (DTC0833) for the P0833 Contact switch for the end stroke of the P158A clutch (DTC158A) P0806 | Circuit for clutch switch (DTC0806) Nobody seems to have ever dealt with this before, and I've been trying to track down a test plan for it for quite some time. have twice used authentic Renault parts to replace the master cylinder The one thing I've noticed about real-time data is that the end point is always the same. Any assistance would be greatly appreciated. Link to comment Share on other sites More sharing options...
TillyBytes Posted 27 minutes ago Author Share Posted 27 minutes ago https://www.amazon.com/s?ascsubtag=v1-2d4aab-621520-fcac904a8b-k&k=Renault+master+cylinder Link to comment Share on other sites More sharing options...
TillyBytes Posted 26 minutes ago Author Share Posted 26 minutes ago I am unable to determine the source of the problem as it pertains to the start-stop function. Link to comment Share on other sites More sharing options...
Uneripty Posted 26 minutes ago Share Posted 26 minutes ago I was wondering how many years this car battery has been in service. Link to comment Share on other sites More sharing options...
TillyBytes Posted 25 minutes ago Author Share Posted 25 minutes ago This battery is completely new. I just need to know the voltages and known good data coming out of the sensor pins when it's turned on and also how to disconnect it, because it's had everything possible. it's equipped with an ECU and BCM Everything that comes to mind Link to comment Share on other sites More sharing options...
Uneripty Posted 25 minutes ago Share Posted 25 minutes ago Better yet, specify what you have done and why you have done it; for example, provide the diagnostic data and error codes that led you to believe the ECU and BCM needed swapping. Link to comment Share on other sites More sharing options...
Uneripty Posted 24 minutes ago Share Posted 24 minutes ago Specifically, which sensor? Link to comment Share on other sites More sharing options...
Patagil Posted 24 minutes ago Share Posted 24 minutes ago Those are the switches that go on your clutch pedal; anyone who has ever changed the cabin filter in a Scenic 3 will recognise them. Link to comment Share on other sites More sharing options...
Uneripty Posted 23 minutes ago Share Posted 23 minutes ago Here is a consolidated thread. Any comments that don't fit together demonstrate why we prefer one thread per topic rather than several. Link to comment Share on other sites More sharing options...
