JetstreamJay Posted 23 minutes ago Share Posted 23 minutes ago Greetings everybody, Prolonged observer For the last twelve months, a mmi box from DroidUK has served me admirably. I am looking for instructions on how to set up a reverse camera but haven't been able to locate any. Anybody have any advice, please? Link to comment Share on other sites More sharing options...
JetstreamJay Posted 22 minutes ago Author Share Posted 22 minutes ago https://www.amazon.co.uk/s/?search-alias=aps&field-keywords=BMW+MMI+box+CarPlay+Android+Auto Link to comment Share on other sites More sharing options...
MrTinkerFix Posted 22 minutes ago Share Posted 22 minutes ago Running it behind the glovebox and down under the sill trims and up behind the C post trim is one easy option, or you can run it behind the glovebox and up behind To fit into the space between the body and the headlining, we used a post trim and raised it above the door seals. It can follow the same plastic trunking on the lid hinge as the current wiring and run to the boot lid. I seem to remember taking the nearby route. Link to comment Share on other sites More sharing options...
JetstreamJay Posted 21 minutes ago Author Share Posted 21 minutes ago Thank you, that's alright. I was worried because the convertible's trunk opens in two directions. Link to comment Share on other sites More sharing options...
HushedGamer Posted 21 minutes ago Share Posted 21 minutes ago Ignore the part about the roof lining because you don't have one. It's a convertible, not a regular 4 series. My apologies. Just follow the existing wiring for the boot lid routing, which should be the same. Link to comment Share on other sites More sharing options...
JetstreamJay Posted 20 minutes ago Author Share Posted 20 minutes ago Thanks! I'll try to get it sorted over the weekend, assuming it stops raining, because it should arrive then. Link to comment Share on other sites More sharing options...
JetstreamJay Posted 20 minutes ago Author Share Posted 20 minutes ago Amazon.co.uk : Automatic Transmission Fluid Link to comment Share on other sites More sharing options...
