CrawlerTagz Posted 35 minutes ago Share Posted 35 minutes ago At the Volkswagen dealership, I had the water pump and thermostat replaced approximately two weeks ago after a warning light and coolant leak occurred. After two weeks, I noticed a slight decrease in the coolant level and the activation of an additional coolant light. Took it in for inspection at the same VW dealership. According to their findings, there is no indication of coolant leakage or overheating. There may be infrequent activation of the check coolant light, which indicates that trapped air bubbles are causing the coolant leak. However, I'm wondering if the air bubbles won't be released a few days rather than two weeks following the repair. Additionally, I was unable to take it to the VW dealer for inspection for two days because the coolant light remained illuminated throughout. Is it just me, or can the coolant light really remain on for no apparent reason? Many thanks Link to comment Share on other sites More sharing options...
MundeDas Posted 35 minutes ago Share Posted 35 minutes ago Their system is quite intricate, so it's certainly doable if it's a diesel. You need to stop driving with the light on and get some coolant to refill it. It should remain off after being topped up; if it returns to its original state, it indicates an issue. Link to comment Share on other sites More sharing options...
CrawlerTagz Posted 34 minutes ago Author Share Posted 34 minutes ago I have filled up the coolant in my 1.5 evo petrol vehicle, and the warning light is still on. Do I have engine overheating or coolant loss on my hands when I see the red check coolant light? Link to comment Share on other sites More sharing options...
MundeDas Posted 34 minutes ago Share Posted 34 minutes ago Coolant level is what it will be for. The temperature gauge will display overheating. There is a chance that the level sender is malfunctioning. Link to comment Share on other sites More sharing options...
Anhartic Posted 33 minutes ago Share Posted 33 minutes ago Level and overheating are indicated by the red light. Link to comment Share on other sites More sharing options...
CrawlerTagz Posted 33 minutes ago Author Share Posted 33 minutes ago What are your thoughts? Is it conceivable for the warning light to illuminate without any actual overheating or coolant loss, unless the sensor is obviously malfunctioning? Link to comment Share on other sites More sharing options...
Anhartic Posted 32 minutes ago Share Posted 32 minutes ago If it flashes, it means there's a problem with the dashboard, such as the sensor or wiring in the Corrado VR6 I'm working on. Link to comment Share on other sites More sharing options...
