spartan Posted 5 hours ago Share Posted 5 hours ago I just got a mini clubman, and it bogs and makes a deep noise when you accelerate and idling is rough. I replaced the intake manifold and breather pipe and installed a new filter, but the engine is still not performing up to par, although it does run slightly better. Are you able to identify it? Link to comment Share on other sites More sharing options...
Radiantecon Posted 5 hours ago Share Posted 5 hours ago To obtain some information, you would have to smoke test the engine and record its data while it is under boost, at idle, and at 3000 revs. These engines are really difficult to diagnose, even with the right equipment, and without it, you are often left with nothing more than a parts cannon. Link to comment Share on other sites More sharing options...
Tactical Posted 5 hours ago Share Posted 5 hours ago Could you please tell me where you are based? If you were in the Southwest, you could bring it to and he would take care of it. Link to comment Share on other sites More sharing options...
spartan Posted 5 hours ago Author Share Posted 5 hours ago Within the West Midlands Link to comment Share on other sites More sharing options...
bourhay Posted 5 hours ago Share Posted 5 hours ago Looks like you might need to swap out the spark plugs. It was the plugs in my Mini Cooper that gave me the same issue. Link to comment Share on other sites More sharing options...
spartan Posted 5 hours ago Author Share Posted 5 hours ago Greetings, my friend After removing and cleaning the spark plugs, I must admit that they did look alright. Link to comment Share on other sites More sharing options...
spartan Posted 4 hours ago Author Share Posted 4 hours ago Amazon.co.uk : 2009 Mini Cooper S spark plugs Link to comment Share on other sites More sharing options...
