CodeCabbie Posted September 28 Share Posted September 28 My 2007 SL350 doesn't appear to have a Bluetooth adapter, so I was wondering if anyone knew where I could get one. Link to comment Share on other sites More sharing options...
DownContent Posted September 28 Share Posted September 28 Does the arm rest have a connector socket? In that case, you can purchase a landline adapter, but it will only enable phone calls and not music streaming. Link to comment Share on other sites More sharing options...
CodeCabbie Posted September 28 Author Share Posted September 28 I don't have the car yet, so I can't see what options are available on the head unit, but does the command center unit have aux in? Link to comment Share on other sites More sharing options...
TheCreakyChair Posted September 28 Share Posted September 28 The head unit is normally configured to make Bluetooth phone calls, but not to stream music. Is it possible to stream music by plugging an adapter into an auxiliary socket, which is typically a 3.5 mm jack plug type? This setup was in my 2008 E Class. Link to comment Share on other sites More sharing options...
LunaCraze Posted September 28 Share Posted September 28 Does your vehicle have COMAND or Audio20 installed? Which version, if any, is it? Contrary to COMAND NTG2.5, which came standard with Bluetooth Telephony, COMAND NTG2 only offered it as an add-on that could be accessed through the center arm rest. Retrofitting COMAND NTG2.5 units—which are essentially obsolete at this point—should be easy to get for cheap on eBay if the car in question is a kerper. Link to comment Share on other sites More sharing options...
LunaCraze Posted September 28 Share Posted September 28 https://www.ebay.co.uk/?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338181132&toolid=10001&customid=2518X1570512Xbcb553702f8652d79ce15c7a9d2bbe3f&subId2=15 Link to comment Share on other sites More sharing options...
