CrawlerTagz Posted September 18 Share Posted September 18 My 2000 APX Roadster has been inactive for the past six months, primarily due to a steering issue. The power steering began emitting a foul noise and exhibited low oil levels, leading me to suspect a power steering hose issue. Equipped with a substitute high-pressure hose, I tackled the task this evening. After extensive searching, I was unable to locate a defective hose, although there was some oil present around the rack. I examined the boot on the passenger side and it appeared to be in good condition. Subsequently, I removed the boot from the driver's side, resulting in a substantial outpouring of oil. It appears that I find myself in a predicament. Is this seal repairable, or must I obtain a new steering rack? Link to comment Share on other sites More sharing options...
CrawlerTagz Posted September 18 Author Share Posted September 18 https://www.amazon.co.uk/s/?search-alias=aps&field-keywords=APX+engine Link to comment Share on other sites More sharing options...
Starat Posted September 18 Share Posted September 18 Updated rack schedule. Ensure you acquire a TT rack. The Golf/Jetta rack is compatible and functions adequately, yet the ratio differs—requiring additional wheel rotations to achieve equivalent tire movement. Should seal kits be accessible and you possess a sense of adventure, you might consider attempting a rebuild. However, that would elevate the period of inactivity. Link to comment Share on other sites More sharing options...
CrawlerTagz Posted September 18 Author Share Posted September 18 I appreciate it; I just discovered an excellent document referenced in this forum that elucidates the entire procedure. I suppose I shall have to attempt it. Inquiry: Are the steering racks and front subframes uniform across all Mk1 models? I am aware of a 2005 roadster with 150bhp that is not equipped with Quattro. Link to comment Share on other sites More sharing options...
CrawlerTagz Posted September 18 Author Share Posted September 18 Amazon.co.uk : tires Link to comment Share on other sites More sharing options...
CrawlerTagz Posted September 18 Author Share Posted September 18 Amazon.co.uk : Audi TT MK3 Quattro parts Link to comment Share on other sites More sharing options...
MundeDas Posted September 18 Share Posted September 18 Regarding steering racks: LHD and RHD are evidently dissimilar. V6 exhibits distinct characteristics as well. Regrettably, in RHD, the FWD and quattro configurations exhibit differences. Link to comment Share on other sites More sharing options...
SushySosa Posted September 18 Share Posted September 18 There are three primary subframe categories: coupe, roadster, and VR6. The final two possess additional reinforcement/threaded bolt apertures. Link to comment Share on other sites More sharing options...
Bedelon Posted September 18 Share Posted September 18 In what context does the QS belong among those variations? The power steering pump emits a screeching noise when it runs dry and likely has a limited lifespan in such circumstances. Link to comment Share on other sites More sharing options...
