MagicPod Posted September 4 Share Posted September 4 Assistance required, please. I possess a 2012 W169 A-Class equipped with a standard MB Audio 20 head unit. I exchanged it for an Android device last year, but its performance was inconsistent, prompting me to revert. I am able to link my iPhone to receive calls, but can it also stream music? I am unable to handle it. I do not observe any indication of an auxiliary input button. Link to comment Share on other sites More sharing options...
Racerse Posted September 4 Share Posted September 4 Depress and maintain pressure on cdc for auxiliary. I am facing an issue; I lack an auxiliary input port. I have recently acquired a cable that I anticipate will allow me to connect via the quad connector to the radio unit, providing a 3.5mm jack for CarPlay integration. Do you have any opinions regarding this? Link to comment Share on other sites More sharing options...
Shadesmo Posted September 4 Share Posted September 4 Examine this. Link to comment Share on other sites More sharing options...
Shadesmo Posted September 4 Share Posted September 4 The vehicle's Bluetooth functions adequately for phone connectivity, and the former owner utilised a device that plugs into the 12V socket to transmit music via an FM signal to the radio. The solution is not particularly refined, yet it is effective. Nevertheless... Upon examining in daylight, I have discovered what appears to be a media interface connection concealed within the glove compartment, shrouded in shadow at the upper rear center of the vehicle, orientated downwards, thus obscuring visibility of the internal contacts. I am unable to conceive of any alternative possibilities, however. If that is the case, all I require (he stated with optimism...) is the appropriate cable and a USB drive, and I will be able to play my music via the head unit. Link to comment Share on other sites More sharing options...
Racerse Posted September 4 Share Posted September 4 Greetings, will this auxiliary cable interface with the rear of the radio unit, thereby providing a 3.5mm jack for CarPlay connectivity? Could someone guide me to a grounding point near the fuse box? Link to comment Share on other sites More sharing options...
Cassole Posted September 4 Share Posted September 4 Hello! Have you succeeded in making this function? I would like to know precisely what actions you took, as I find myself in a similar predicament. I appreciate it. Link to comment Share on other sites More sharing options...
