LimeLing Posted June 16 Share Posted June 16 Hello everyone! When the air conditioner is turned on, what temperature should be expelled from the vents? Link to comment Share on other sites More sharing options...
Mastervest Posted June 16 Share Posted June 16 Is the climate control or air conditioning operated manually? Link to comment Share on other sites More sharing options...
LimeLing Posted June 16 Author Share Posted June 16 Greetings! This is a handbook. Link to comment Share on other sites More sharing options...
Videoman Posted June 16 Share Posted June 16 So long as the temperature you put on the dial is consistent with what comes out of the vents, everything should be OK. Absolute red indicates extremely high temperature, while absolute blue indicates extremely low temperature. In your opinion, is your air conditioner busted? Turning the engine on and off while the engine is running should cause the note to alter (and maybe even a click or clang) as the clutch engages and disengages the pump. When air conditioning stops functioning, it could be due to a lack of refrigerant rather than a costly breakdown. Link to comment Share on other sites More sharing options...
LimeLing Posted June 16 Author Share Posted June 16 After doing that, I can confirm that the engine rpm change and that the compressor clutch is functioning properly; however, in the six years that I've owned the vehicle, I've never had the refrigerant tested, so I share your concern that it may be low. Link to comment Share on other sites More sharing options...
Videoman Posted June 16 Share Posted June 16 You can purchase top-up kits, or at least you could in the past; nevertheless, I was unsuccessful in using them. You can find a lot of mobile air conditioning technicians who can visit your home to inspect the system and add more fluids if needed. Link to comment Share on other sites More sharing options...
