Dudeta Posted 3 hours ago Share Posted 3 hours ago Could someone please tell me where I can locate the E46 hydraulic roof pump's rotating shaft seal? There is fluid within the electric motor, therefore I suspect the leak is coming from the shaft seal; I fixed mine pump last year, but it still has a leak. I have been searching high and low for a tiny enough seal source in the UK, but none have come up. OD 3 millimetres by OD 8 millimetres by 2 millimetres Link to comment Share on other sites More sharing options...
Messand Posted 3 hours ago Share Posted 3 hours ago Is there a real-life part number for it? I doubt so, but it was only an idea. Link to comment Share on other sites More sharing options...
rauman Posted 3 hours ago Share Posted 3 hours ago I thought you said the dimensions were 3 mm ID x 8 mm x 2 mm. From what I've read, the proper dimensions should be 6mm x 16mm x 4mm, therefore this one seems on the tiny side. Link to comment Share on other sites More sharing options...
Dudeta Posted 3 hours ago Author Share Posted 3 hours ago Link to comment Share on other sites More sharing options...
Dudeta Posted 3 hours ago Author Share Posted 3 hours ago it is indeed a very small seal, probably why I'm having so much trouble finding one. Link to comment Share on other sites More sharing options...
Dudeta Posted 3 hours ago Author Share Posted 3 hours ago Hold just a second, I believe you're correct; my callipers seem to be malfunctioning. The measurements were apparently halved by my callipers.wth Link to comment Share on other sites More sharing options...
Dudeta Posted 3 hours ago Author Share Posted 3 hours ago It is tiny, that much is true. Link to comment Share on other sites More sharing options...
Dudeta Posted 3 hours ago Author Share Posted 3 hours ago No, that's wrong. They only sell the whole unit. Link to comment Share on other sites More sharing options...
