Seeking Assistance in Locating a Hydraulic Roof Pump or Motor Seal.
Dudeta
Could someone please tell me where I can locate the E46 hydraulic roof pump's rotating shaft seal?
There is fluid within the electric motor, therefore I suspect the leak is coming from the shaft seal; I fixed mine pump last year, but it still has a leak.
I have been searching high and low for a tiny enough seal source in the UK, but none have come up.
OD 3 millimetres by OD 8 millimetres by 2 millimetres
I thought you said the dimensions were 3 mm ID x 8 mm x 2 mm. From what I've read, the proper dimensions should be 6mm x 16mm x 4mm, therefore this one seems on the tiny side.
