Putting Back the Back Air Bags
CrawlerTagz
I've deployed the Viano's rear air bags.
When I reinsert them, this time devoid of air, they seem crooked, and I can't get the trailing arms to stand up straight.
When I was younger, I don't even recall if they came with a strap to keep them in place during installation.
Anyone who has reinstalled these and can tell me what to do next?
I used my air compressor to partly fill the new air springs on my S212 to let them settle in before I attached the hoses, but I can't say for sure how different they are. Checked out
I also attempted something similar, but it was unsuccessful.
Finally, I took them off once more.
I was able to get them to fold and collapse with the help of some red rubber oil. In its current form, the rubber is unable to travel through it.
I inflated the tyre using the rear manual control while lowering and removing the jacks from the trailing arms after recharging the battery and starting the ignition cycle.
You may reshape the bag to remove its contents and remove it from the car by using a modified USB cord and battery pack to activate the bag solenoid, as you learned in class. Afterwards, re-fit it and apply force and pressure at the optimal rate, which is something you'll have to feel out.
On the other hand, I once returned a brand new Mercedes bag because it wouldn't inflate properly.
