Uneripty Posted February 2 Share Posted February 2 Hello everyone, it became audible in December and has already completed 200k. The mechanic had to replace the DPF since it had become completely blocked. It worked OK for three weeks, but now it's acting up again, and I'm not sure whether it's worth mending because of how much it would cost. Please let me know your opinions on this. Link to comment Share on other sites More sharing options...
Startle Posted February 2 Share Posted February 2 It seems like they didn't address the underlying problem and instead addressed the symptom by installing a new DPF if it began happening again after the replacement, even if it was due to a clogged DPF. Link to comment Share on other sites More sharing options...
Uneripty Posted February 2 Author Share Posted February 2 I see your point. I have to figure out the root of the problem! Best regards Link to comment Share on other sites More sharing options...
Mezuzzi Posted February 2 Share Posted February 2 It's clearly a big issue when it takes three weeks to clog a dpf. Honestly, I'd give it back to them. Link to comment Share on other sites More sharing options...
Dudeta Posted February 2 Share Posted February 2 Similar to what Johnny said, I doubt it would be possible to block a real DPF in that amount of time unless it was a knockoff. Any decent technician would first try to figure out why it was blocked, then address the underlying problem, before considering replacing the DPF. Link to comment Share on other sites More sharing options...
Uneripty Posted February 2 Author Share Posted February 2 Since it hasn't been examined recently, I can't say for sure if the present DPF is blocked; however, I can say that he installed a cheaper, non-genuine BMW one. Is anybody aware of anything that could be triggering the problem? There could be a few possibilities, I suppose! Link to comment Share on other sites More sharing options...
Mezuzzi Posted February 2 Share Posted February 2 Without a fault code scan, you'd have to guess, which may be costly. Link to comment Share on other sites More sharing options...
bourhay Posted February 2 Share Posted February 2 The hardships of diesel ownership...why subject life to more strain for a few more miles per gallon? Link to comment Share on other sites More sharing options...
