Draining the cooling system of the Mk5 Mondeo diesel
LunaCraze
Can someone inform me of my error? I am attempting to empty the cooling system, with the heater set to high. I have opened the drain tap at the bottom of the radiator and removed the cap from the expansion tank, nevertheless only approximately 3-4 litres have been expelled. What additional steps should I take?
Which hose must I detach to introduce air and expel the majority of the coolant from the system? Clearly, when I proceed with this, the thermostat will be closed; hence, I may need to detach multiple hoses surrounding the thermostat housing. Which hoses would facilitate this process?
