LunaCraze Posted November 14 Share Posted November 14 Can someone inform me of my error? I am attempting to empty the cooling system, with the heater set to high. I have opened the drain tap at the bottom of the radiator and removed the cap from the expansion tank, nevertheless only approximately 3-4 litres have been expelled. What additional steps should I take? Link to comment Share on other sites More sharing options...
NightHawk47 Posted November 14 Share Posted November 14 It will not completely expel all of it unless air is forced through the system, likely a significant amount within the engine block and the vehicle's heater. Link to comment Share on other sites More sharing options...
LunaCraze Posted November 14 Author Share Posted November 14 I utilised a cordless blower in the expansion tank until no fluid emerged from the drain faucet; nonetheless, only approximately 3-4 litres were expelled. Link to comment Share on other sites More sharing options...
LunaCraze Posted November 14 Author Share Posted November 14 Which hose must I detach to introduce air and expel the majority of the coolant from the system? Clearly, when I proceed with this, the thermostat will be closed; hence, I may need to detach multiple hoses surrounding the thermostat housing. Which hoses would facilitate this process? Link to comment Share on other sites More sharing options...
