HeadlinesQuick Posted November 1, 2025 Share Posted November 1, 2025 I possess a 67-plate 430d, and while manoeuvring slowly and turning, I hear a knocking noise that appears to originate from the driver's side. The steering is smooth, and there is no noise when the wheel is turned in place, but only while turning when moving slowly. I am removing the tray to inspect the suspension components in case it is an arm or similar part. Can anyone provide guidance or identify the issue based on my description, specifically about if it is likely a bearing problem? I have read that some automobiles may lack a repair kit due to varying steering racks installed. Could someone inform me about the specific steering rack I possess and whether a repair kit is available? Link to comment Share on other sites More sharing options...
Accomis Posted November 1, 2025 Share Posted November 1, 2025 It is likely the thrust piece; the 4 series includes racks with an available thrust piece repair kit, as I have replaced several. With the engine off, oscillate the steering wheel laterally and observe for any noise emanating from the rack. Link to comment Share on other sites More sharing options...
HeadlinesQuick Posted November 1, 2025 Author Share Posted November 1, 2025 I have shaken the steering wheel with the engine off, and there is a knocking noise. Could you kindly direct me to the appropriate part? Link to comment Share on other sites More sharing options...
Accomis Posted November 1, 2025 Share Posted November 1, 2025 https://www.ebay.co.uk/itm/405136040920?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=jge0npugr_m&sssrc=4429486&ssuid=eVPsP3o3TNu&stype=1&var=&widget_ver=artemis&media=COPY Link to comment Share on other sites More sharing options...
Accomis Posted November 1, 2025 Share Posted November 1, 2025 https://x8r.co.uk/mwdownloads/download/link/id/206 Link to comment Share on other sites More sharing options...
Accomis Posted November 1, 2025 Share Posted November 1, 2025 The initial link I obtained, but you may utilise the part number to compare prices. Link to comment Share on other sites More sharing options...
HeadlinesQuick Posted November 1, 2025 Author Share Posted November 1, 2025 Thank you for your assistance. I lack proficiency in automotive matters; do you possess the part number or know where I may obtain it? Link to comment Share on other sites More sharing options...
Accomis Posted November 1, 2025 Share Posted November 1, 2025 The part number in the listing concludes with 974. Link to comment Share on other sites More sharing options...
Accomis Posted November 1, 2025 Share Posted November 1, 2025 π Link to comment Share on other sites More sharing options...
