MollyCircuit Posted October 4, 2025 Share Posted October 4, 2025 I purchased a car for my son’s 16th birthday, and it was an enjoyable vehicle. Regrettably, after around 2000 miles, it had failures of the high-pressure fuel pump, timing chain, water pump, and developed an oil leak. I was unable to address all of them immediately. The son was driving on the motorway when the water pump malfunctioned, causing the engine to overheat and resulting in a loss of compression. Seeking to do an engine replacement Link to comment Share on other sites More sharing options...
MollyCircuit Posted October 4, 2025 Author Share Posted October 4, 2025 Is it feasible to use a non-S N18 engine and incorporate a turbocharger onto the long block? Link to comment Share on other sites More sharing options...
WordSnoop Posted October 4, 2025 Share Posted October 4, 2025 The pistons are identical; the N18 has direct injection, while the N16 and N12 use port injection. Link to comment Share on other sites More sharing options...
JamesStv Posted October 4, 2025 Share Posted October 4, 2025 I regret to learn about your situation and wish you well with the exchange. Link to comment Share on other sites More sharing options...
rauman Posted October 4, 2025 Share Posted October 4, 2025 The N18 has direct injection, whereas the N16 and N12 use port injection. Link to comment Share on other sites More sharing options...
WordSnoop Posted October 4, 2025 Share Posted October 4, 2025 There is an echo in this space, amusingly. Link to comment Share on other sites More sharing options...
