MagicPod Posted July 24, 2025 Share Posted July 24, 2025 Greetings everyone, I want to replace the gearbox and differential oil in my 2015 B47 118D, manual 6-speed transmission. I want to ascertain the oils required for both. Thank you. Link to comment Share on other sites More sharing options...
Bedelon Posted July 24, 2025 Share Posted July 24, 2025 Consult realoem.com to ascertain BMW's specifications, then proceed with cross-referencing. Link to comment Share on other sites More sharing options...
MagicPod Posted July 24, 2025 Author Share Posted July 24, 2025 Thank you; I will attempt it immediately Link to comment Share on other sites More sharing options...
Strongspoi Posted July 24, 2025 Share Posted July 24, 2025 As previously said, you may contact BMW directly to request the necessary information; they will thereafter provide you with a component number, after which you may deny the purchase. Link to comment Share on other sites More sharing options...
MagicPod Posted July 24, 2025 Author Share Posted July 24, 2025 Link to comment Share on other sites More sharing options...
MagicPod Posted July 24, 2025 Author Share Posted July 24, 2025 I attempted that, and they responded with this đŸ˜‚ Link to comment Share on other sites More sharing options...
MagicPod Posted July 24, 2025 Author Share Posted July 24, 2025 đŸ¤‘ Link to comment Share on other sites More sharing options...
Thenornpo Posted July 24, 2025 Share Posted July 24, 2025 Real OEM - just input the last seven digits of your VIN to get detailed information. This is the information I can see by using the drill-down feature by model, assuming a construction date of July 2015. Link to comment Share on other sites More sharing options...
Thenornpo Posted July 24, 2025 Share Posted July 24, 2025 Link to comment Share on other sites More sharing options...
Thenornpo Posted July 24, 2025 Share Posted July 24, 2025 You must do due diligence to verify its applicability to your VIN. Link to comment Share on other sites More sharing options...
MagicPod Posted July 24, 2025 Author Share Posted July 24, 2025 Thank you very much; both options precisely align with the pricing provided by BMW, indicating they are suitable choices. Thank you once again. Link to comment Share on other sites More sharing options...
