Issue subsequent to the lower gearbox
DolSquirrel
Greetings I am experiencing an issue with the replacement of the ZF8HP automatic gearbox on a 2012 BMW F30 320d with 184 miles. I am experiencing a CD94EC error, and the vehicle jerks during rapid acceleration. Do you own a solution to this issue? Thank you so much for your response.
You have already addressed that question in your first article.
Any modifications of such kind need coding, since all components are programmed to the vehicle, and each module has a serial number that must be altered, even if the part is identical.
