Syncephe Posted 17 minutes ago Share Posted 17 minutes ago Greetings once more Sunroof made of panoramic glass is on mine. The sunroof tray is damp and there are little water stains on the seats from the recent heavy rain. Typically, the car is parked facing uphill, but this time it was parked facing downhill. I have verified that the drains mentioned in the owner's manual—located at the back of the sunroof and leading into the rear wheel arch—are indeed clear. Even with the deflector, it's hard to see, but there's no indication that the front of the assembly has any drains. Please, someone, tell me if the sunroof has any drains in the front. If not, I will need to ensure that I always confront challenges head-on. I am grateful. Link to comment Share on other sites More sharing options...
Adv3nture Posted 17 minutes ago Share Posted 17 minutes ago I always assumed they were at the front (it's been a long since I've had a sunroof), so you got me on that. They were all up front when I was a kid, but they've all retired by now. bump.. Link to comment Share on other sites More sharing options...
Adv3nture Posted 16 minutes ago Share Posted 16 minutes ago Amazon.co.uk : Automatic Transmission Fluid Link to comment Share on other sites More sharing options...
Syncephe Posted 16 minutes ago Author Share Posted 16 minutes ago I am grateful. Even though I'll have to search more, I anticipate seeing them up front as well. Link to comment Share on other sites More sharing options...
Cleverco Posted 15 minutes ago Share Posted 15 minutes ago You should be able to spot a piece of rubber pipe sticking out of the door hinges if you look at them from the front. Link to comment Share on other sites More sharing options...
Syncephe Posted 15 minutes ago Author Share Posted 15 minutes ago Thank you. I will evaluate tomorrow. Link to comment Share on other sites More sharing options...
Syncephe Posted 15 minutes ago Author Share Posted 15 minutes ago 😝 Link to comment Share on other sites More sharing options...
